I know this isn't a garage question but this place has the knowledge. My house has a side room, about 10x16, that was added on by a previous owner well after the original house was built. While the old house is built over a basement, that room is built over a crawl space that is accessible via the basement. The exterior walls of that crawl space are insulated with spray foam. The bottom of the crawl space appears to be sheeting over pea gravel. The floor is uninsulated.
Today I noted that the floor temperature in that carpeted room was 56F. That certainly makes the room feel colder in the winter. Is there any reason why I shouldn't insulate the underside of that floor? Given the spray foam, I'm assuming the original builder had some plan for insulation and perhaps wanted to make sure that area never froze? The only services that run under the room are electrical, a radon pipe and two flex ducts that service the room.
My plan was to put some fiberglass insulation between the joists with the vapor barrier towards the floor. Any issues with that plan?
Thanks!
Thanks!
