question about leveling concrete floor for laminate flooring
bimmerZ5
i've been in the process of installing laminate flooring throughout my entire 1st floor, about 1200 sq-ft total. the floor originally had a few sections of carpet and then parquet wood tiles. as i remove the parquet tiles, i'm discovering that the previous owner glued the parquet onto linoleum flooring that I think came originally with the house when it was 1st built.
after removing the parquet and linoleum, i see what appears to be pink leveling compound that was used in small patches here and there. a lot of it is cracking or coming off as i remove the parquet and/or linoleum. in particular, there's a 4'x2' patch in the kitchen area that is coming off. at it's thickest area, it appears to be about 1/16 inch thick. this is probably the thickest patch of the pink leveling compound that i've found thus far.
i'm installing 7mm laminate flooring, the click-lock type as a floating floor over 3-in-1 underlayment (the type with white foam balls between a vapor barrier and a top plastic sheet). the underlayment is about 2-3 mm thick and is somewhat compressible since it has the foam balls and air gap between the two outer layers.
so, my question is, should i be concerned about fixing up the 4'x2' patch of leveling compound before i put down the underlayment + flooring? to "me", not being a professional at this, I think the area is wide enough and the thickness of the original patch of leveling compound seems thin enough that it might not matter much after i lay down the 3-in-1 underlayment and flooring.
i'm still in the process of scraping the concrete floors and haven't put any flooring down in this area yet so I figure I should ask before I do that. expert opinions are appreciated...
willyswonka
New Orleans, LA
The underlayment is designed specifically to absorb shock and not deform over time so, if it is working right, it won't serve to level the floor at all. However, most standard (4' plank) laminate can handle 1/8" deviation over a 6' span so you shouldn't have to worry about the floor not installing correctly. That said, if having a dead flat floor is important to you, you'll definitely have to put down new leveling compound. If you do, just make sure to give it plenty of time to dry. Even after it is fully cured it can still let off moisture for a few days and you don't want to trap that under the vapor barrier.
