Hey all, I've got a bit of an odd scenario and need to know what's "code" and what's not.
I am replacing a low voltage switch for a power condition (pro audio) in a facility and the install company DID NOT put a low voltage outlet box in the wall to mount the plate/switch to. They just drilled into the wood and mounted the switch that way. Well, I'm replacing said switch due to some issues with the current setup.
What is the code for low voltage switches and mounting? Do I NEED a low voltage box in the false wall to mount the switch/plate to or, is it kosher to leave it as is? Personally, I feel it VERY unprofessional that a box was not installed initially and also feel it violates electric code but, can't find any references to the code (aside from the duh clause) that would require it.
Again, this is LOW voltage. There is maybe 12v max (signal) running to the switch on the wall-plate. It is simply a push button to start the on or off sequence for the equipment. Furman power conditioners and switches and sequencer if you are curious. I'm not looking for an aspect on the audio end, I need the electrical regulations as to how I show proceed and replace the switch without making ME liable for wrongfully installed equipment.
