Question about oil drums
zcbauer89
NW OH
I want to get bulk hydraulic oil for my shop, and was wondering what the epoxy phenolic liner is used for in oil drums? Is that needed for oil? Or should I just get a regular no lined steel drum? Thanks all.
Milton Shaw
Who are you going to get the bulk oil from. They probably have drum with oil already in it. If you are a bulk user 30-50 or more gallons a week they might furnish tank, pump etc. They furnish them to tire stores all the time for engine oil changes and should furnish them for hydraulic oil also. A waste tank with pump out fittings looks like would be needed also if you are truly using a large amount of oil each week. Check around for different deals from all the major oil distributors, the deal will be different.
sberry
Brethren, Michigan
You need a clean tank, nothing special. As a side note I got away from bulk and shop for sales and stock up on buckets. I bought a barrel of gear lube because I got a super deal, got a couple big trucks used changes and still got 1/2 left.
I got off barrels, they were a problem and the small difference in price is worth the packaging and I never had much better than a farmer system anyway, use also went down over the years.
There are places a barrel is easy, easy to pump in to a pour container.
Z
zcbauer89
NW OH
Well I wanted to take advantage of the sale that my dealer is having, buying the drum already filled would be $140 more, so I thought about just getting a drum, and having it filled. Just kicking around ideas right now. Thank you all for your input.
