panchohughes
I have never had any filter or lube inline in my compressor before, but as I am getting my new shop situated I installed RapidAir lines. As part of this i also bought an inline air filter/water separator. It came with a sheet of information, but no instructions really other than;
-its poly-carbonate, so dont use lube that is not compatible
-install so air flow follows the arrows on top.
My question is, there is a lever on the front that retracts downward, and allows the housing to rotate. At first I thought this was perhaps how you disconnect the bowl to replace the filter. But after messing with it for some time, I don't think that is the case. I think to change the filter i have to remove the plastic screw and the knurled nut from the bottom. But before I start needlessly taking it apart, i figured i would ask here. ( I did some google searches, but have not found the answer )
Its a SAF4000 from PneumaticPlus.com
Thanks for any input.
