Capt. Spaulding
I got this Proto at a estate sale today and took it apart to clean it up. When I opened it up I noticed the springs were a bit bent and one was much worse than the other. Once everything went back together it is functioning but when used in the “on” position the spring is not providing enough tension and the ratchet is skipping and just not functioning like it should. My question is, do I need to find Proto springs to replace them with or is there other springs I can use? Thank you in advance.
