question about pumping "cleaning fluids" with a utility pump
mds33200
Hi I purchased a 1350 gallons / hr. utility pump at my local hardware store.
I put the pump in a bucket and attach a hose, then attach a spray handle to the end of the hose (which restricts the pumps water output flow). By doing that I can create a jet stream of whatever liqid is in the bucket. I do this to clean items.
I was reading the pumps user manual and it says designed for water 77 F max. It says do not pump other fluids, especially cleaning fluids with the pump.
I was wondering if they say that cus it is a saftey hazard, or if they say that because cleaning fluid will cause extra wear and tear on the pump? I dont care about wear and tear or if it shortens the pumps life, but I do care obviously if it is a fire hazard. Now obviously I would not put gasoline or something like that in the bucket, the only things I use is dawn dish soap, vinigar, and another cleaning chemical called "spray-9". I always dilute with water so it is never 100% concentrated. I do use hot water, I would estimate 110 F. So is it safe to use these chemicals with this pump? Or do they say that just just to prolong the life of the pump?
Here is a link to the pump- http://www.harborfreight.com/16-horsepower-submersible-utility-pump-68422.html
