earthwyrmjim
I set up a home gym in my garage for barbell training, and it gets overwhelmingly hot/cold in NE Ohio for ~2-4 months out of the year, so naturally I want to insulate so I can heat/cool for those months and train without dying of heat stroke or hypothermia. The problem is that my garage only has a rafter tie for every other rafter, so I end up with 32" OC 2" x 6" x 24' ties that I need to insulate between. I really don't want to install more 24' rafter ties just to cram insulation between them (assuming I can, haven't done the trig to figure that one out), and I'd like to avoid cheaping out by hanging fiberglass if I can.
So my question is:
For 32" OC rafter ties, can I install rockwool "sideways" (i.e. cut ~32" lengths and rotate 90 degrees)? Are there any major problems that may arise from doing this? Only thing I can think of is possible sagging from each segment being double the weight for the same bearing surface area, and excessive amounts of waste since batts are 47" long.
So my question is:
