b-boy
I have a pole barn about 250 ft from my main house. I've got a sub-panel in the pole barn. The sub-panel is properly wired, and there are 2 ground rods in place.
There is a 15x30 lean-to about 50 ft from my pole barn. I'd like to trench and run wire to this structure. I want to be able to add some outdoor lights and an outlet.
I'd like to add a circuit to the sub-panel and run it out through the wall underground, and into the side of the lean-to. I want to add at least 1 outlet, 1 switch, and some outdoor lights. This area is basically covered, but can be exposed to the elements during a heavy storm. I'd most likely use a GFCI breaker at the sub-panel.
Any issues doing this?
