Question about running air lines
b.preston
Hello, I am in the process of running my compressor air lines in my shop. I am using 3/4" copper pipe through out. I will be running a flexible line from the comp. to the 3/4 copper. My question is, if I use a 3/8 flex line to the 3/4 will this have an adverse effect on the air traveling down the line? I might mention the 3/8 line will be about 3ft.
Thanks Bob
Motofixxer
Technically yes. Would you notice the difference? Probably not. But I just went to a hydraulic hose place and had em make me a custom 3\4 hose. You can also find them I believe at tractor supply type places.
b.preston
I do have a shop that is not too far away that I believe could make the hose. It does make sense to not reduce the line right off the comp. thanks for the advice Bob.
scarpozzi
Tennessee
There are equations to calculate the loss...It's probably easier if you look up the gas line charts as they are really more specific about pressure drops as a result of pipe length and diameter. In agreement with Motofixer. You probably won't notice anything, but you just added a bottleneck right off the bat. I want to say 3/8" is pretty standard for air fittings/hoses and you could have run 1/2" copper and saved some money....but if you were ever to get a larger compressor with 3/4" output and want higher pressure, further away, you'll have less pressure drop due to the distance.
sberry
Brethren, Michigan
It wont mean much, the 3 ft is pretty short and likely have more than that on the other end after a regulator. I like the hyd line idea for a couple reasons, but one being its cheap and simple, comes with fittings clamps etc.
HTGTS350
I had 1/2 for about 2ft from the compressor and then upgraded to 3/4 and I noticed the difference at my blast cabinet, it cost me about $30 to upgrade to 3/4. I also had 1/2 for about 3 ft to the blast cabinet and it cost about $40 to upgrade to 3/4, between to 2 I spent $70 and I would do it again tomorrow for the gain In flow I got.
J Persons
Louisiana
TP Tools sells a 3/4" steel braided line made specifically for compressors. It's about $35.00 for a 3/4" X 12" line.
78Bird
Charlotte, NC
Northern tool sells a chunk of 3/4 hydraulic hose that would work as a flexible connect. It's not too long, but if you can terminate the hard line right at the compressor you can make it work.
Falcon67
Merkel, TX
You can also get 36" hydraulic 3/4 line at a Tractor Supply, or have one made at about any hose dealer.
akdiesel
Wasilla, AK
The only thing I see being an issue is it could JT. In other words it will cool down rapidly when entering the 3/4" line due to a pressure drop when high air demands are needed.
But most of you tools also use 3/8" or 1/4" fittings so there is also a restriction there.
Winmon
Sequim, Wa
This is where I get confused on compressor lines/sizing. My compressor has a 1/2" outlet fitting on it so what advantage would there be in 3/4" hose to my 3/4" hardline?
Fixnair
Sapulpa OK
At 100 PSI a3/4" pipe will flow something like 600 CFM. A 3/8 hose something like 125 CFM. Both figures are dependent on the length of the pipe. Longer pipe = less flow. Plus each fitting decreases flow. Eg. One 90 *elbow = 10 feet of pipe.
I don't know what kind of tools you will be using but I doubt you will be needing more than 3/8 hose can supply.
The maximum flow will be determined by the smallest restriction in the system.
Motofixxer
Most tanks have a large reducing bushing that can be replaced. Mine reduced to 1/2" also. I used a big socket, some elbow grease, and an impact to remove the bushing and got one from a plumbing supplier that reduced to 3/4". Cost me about $4 and some time.
If you have a welded in bushing, then your SOL unless you cut it out and replace it. Good luck on that. :wtf:
Any restriction you remove is better. Also I would recommend using High Flow couplers like the Milton Type V. Do a search to read the tons of discussions already had regarding them. They will make a noticeable difference also.
coljar
Belpre, Ohio
What are you going to be doing in your shop? What kind of air tools will you be using? Blast cabinet?
sberry
Brethren, Michigan
__________________
for long runs.
This is likely pretty accurate, I think it might be a cheap way to feel a bit better about yourself.
Plus the distance factor. 3/8 doe 2 ft before the regulator that connects to a 3/8 hose is something the operator could never notice.
