Question about T-8 bulbs
CoopVA
Virginia
If you use a T8 bulb on a T12 ballast you will shorten the life of the bulb as the T12 ballast will over "tax" the bulb. If you have a T8 ballast running a T12 bulb you will have premature ballast life as the t12 bulb takes more to run and will over work the ballast.
6768rogues
Western NY
I have a 4 tube fixture in my kitchen that used T-12 bulbs. I bought a new 4 bulb T-8 ballast and new sockets that hold the bulbs, along with T-8 bulbs at the local big box store. Then I converted the fixture to T-8. Following the wiring diagram on the ballast was easy and they are wired more simply than T-12 lights.
You may not have to replace the bulb sockets but one of mine was broken and the others were old and weak. Not a big deal. We converted hundreds of T-12 fixtures to T-8 at the school where I used to work. If you have a decent fixture, it is less money than replacing the whole fixture. You should not just replace the bulbs.
Kevin C
Portland OR
Is it possible to use T-8 tubes in a light fixture that used T-12 tubes? :headscrat
It depends on the fixture. A lot of fixtures use a dual rated ballast that will work with either bulb.
Older T12's, probably not (typically a magnetic ballast).
The only way to know for sure is to look at label on the fixture (It should say if its a dual rated fixture) or open the fixture up and check the ballast.
