600SL
When I sold my house in CT. The home inspector made me put a green bonding screw in the sub panel in my garage. Which I thought was wrong.
When I came here to NC an electrician told me the bonding screw was being debated at that time ~ 3 years ago for NC. Weather you put it in or leave it out on a sub panel was at that time under reconsideration for North Carolina.
So OK I now have a steel building this its own meter to a 200 amp main CB panel. The green screw is in place in the main panel. I am now putting in a 100 amp sub panel. Both the sub panel and main CB box are attached to the steel building by being physically mounted to the steel building and connected to each other by both EMT with compression fittings and a #6 ground wire. What difference can this green bonding screw possibly make on this setup.
Can anyone give me a scenario of a possible fault that could occur if I were to leave the green screw in the sub panel.
Can anyone give me a scenario of a possible fault that could occur if I were to not put the green screw in the sub panel.
Would there be any difference if this was a wood frame building.
Would a voltage potential be expected between neutral and ground at the sub-panel if the green screw is out.
Does anyone know where NC currently stands on the green screw.
