Question about Tool chest and vise mounting
glockman25
I have the Harbor freight 56" tool chest
I would like to add a butcher block but no ikea near me. Also I am wondering if its possible to mount a vise on top of the chest and how i would go about it pictures if possible
Jawn
Stuck in traffic, GA
I wonder if the Sears block bench top is wide enough?
As for the vise... if it's a fairly small one, I'd bolt it right to the block top before putting that on the tool cabinet... if it's a big vise, maybe consider mounting it to a steel plate, then mounting that to the box/block top?
You definitely need something besides the metal top to attache the vise. Ply works bit flexes quite a bit, any laminated block top is better.
Another option for material is laminated bamboo. Its really tough.
wnstwolf
New York and PA
Just remember the box is on casters and even when brake is on it will move if you start to really pull,tug,beat, on the vise. Like mentioned a smaller one is good lagged to the top but unless it is attached to a stationary mount the use of a vice is somewhat limited..or at least a pain to use..
G
glockman25
will be used for building rifles and maybe holding a strut or something of that nature...
what u guys think now knowing what id be using it for?
Depends on what your definition of "building rifles" is... If you plan on re-barreling bolt action rifles, you will need special tools and a good vise and that vise better be on something a lot more solid than a rolling tool cabinet. If you are doing break down rifles (AR15 "Mattel" style) probably OK for some use.
NUTTSGT
Northern Central Ohio
Anything mounted on wheels will have the tendency to move around unless you get it off the wheels. I wouldn't be afiad of making a top out of 2 layers of plywood and with 2x4s sandwiched inbetween.
