Question about water heater connections
genkinyc
Hi Guys,
Does such a thing exist as a 7/8" to 5/8" hose adaptor?
I have a water heater installed that has 7/8" hose coming off it and I need to connect it to a new engine that I installing - the new engine is 5/8 hose barb connections, the old was 7/8"
I have tried Home Depot, West Marine, spoken with Raritan (the heater manufacturer) and also tried a couple of local plumbing supply houses "plumbing only comes in 1/2" 3/4" and 1" size!"
So, if I can't find a hose adaptor I would have to purchase expensive new hose and re-fiiting to the water heater...
Do any of your gurus our there have a solution ?
Thanks in advance
G
genkinyc
Hi,
Unfortunately no, I cannot transfer the hose barbs from the old engine.
It seems impossible to find a reducing coupler from 7/8 to 5/8...
Thanks
rlitman
Long Island
I had a similar issue with vacuum hoses on my Jeep. One side was one size, and the other side was another size. It came from the factory with a formed hose, but that part was unavailable at the dealer.
I ended up buying brass hose barbs in both sizes at HD, sawed both in half, and brazed the two together.
G
genkinyc
I can get a picture when I re-visit the boat on Friday.
I have a water heater already installed with two hoses attached that are 1 7/8"
I want to attach them to 1 5/8" hose barbs on the new engine that I am installing and was hoping for a reducing coupler.
The coolant from the engine passes through the hoses and through the marine water heat exchanger to create hot water for the boat :)
One of these puppies;
http://raritaneng.com/raritan-product-line/water-heaters/1700-series-marine-water-heater/
Thanks
zmaxmotorsports
South of omaha
Ah,you forgot to mention the part about a boat!:lol:
That's what was throwing me off ,I was picturing a water heater in your house connected to a,sbc.:lol_hitti
You should be able to get a hose barb Luke that at any decent box store.
G
genkinyc
I should have mentioned that it's a sailboat - DOH !
Oh man, and I typo the hose sizes,
It's 7/8" to 5/8" that's what I need.
Thanks !!
G
genkinyc
Thanks for the responses.
I still have been unable to find a hose barb - 5/8 to 7/8.
The water heater manufacturer tells me that I can replace the fittings at the heater side to 5/8 - but that's a lot more work (I would have to remove the water heater to reach the fittings, purchase new expensive marine grade hose)
Thx
BillK
Beautiful Southern Maryland
What engine is it ? Are you sure you cant take the hose fittings out of the new engine and replace them with ones for the 7/8 hose ? Are the fittings threaded in or pressed in ?
rlitman
Long Island
And have barbed inline fittings on each side of it? That's a lot of potential places for leaks, but I like that idea a lot more than stretching or compressing a hose.
If it were me, I'd still go with my original recommendation of making a brass to brass adapter. Either by brazing two pre-made adapters together (the easiest and cheapest way), or by turning something on the lathe.
But a thought just came to mind. You could take a piece of thick wall copper tubing, anneal it, and press a swage into the end to stretch it to the thicker size. With a little rolling of the ends, and a gently made bubble flare on each end, you could make an adapter out of copper without too much effort.
DenisG
Milwaukee
Get hose barb adapters to 1/2" NPT pipe and connect them with a 1/2" NPT coupling. (Or use hose barb adapters with opposite NPT genders.)
