trooper1954
Hi All,
I have a utility trailer that needs sandblasting and re-painting....last time I did this ten years ago I did it all with a wire wheel, but I'm now thinking I would try wet sandblasting this time.
The problem seems to be that my pressure washer is 3000psi and 2.5 gpm....I cannot find a wet sandblasting set-up that would specifically work with these parameters...they all seem to need more PSI and a greater GPM minimum of 4. Has anyone modified any of these systems to work with lower psi/gpm?
I'm thinking that maybe reducing nozzle size or feed hose diameter may improve performance on the lower gpm units...it seems the problem is in the venturi, and the lower gpm's don't have enough flow to **** up the media.
Anyone's thoughts or experiences would be appreciated.
