Jarcese
Try to find the GE Transformer book somewhere, it has every bank possible in it. The one I posted is doesn't have as many bank combinations. You can probably find the actual book for a couple bucks. I usually carry a few of them and give them out once in a while when people ask me detailed questions when I'm at work 'cause you can get caught up talking shop pretty easily.
I know with a grounded delta straight 240(or 480) bank you can put the neutral and high side on either bushing. Pretty sure it's not possible to get 120/208 3 phase without having the neutral in the middle. If you look at the book I posted, you can get 240 3 phase, 120 single, and 208 single phase out of a bank the way you described. With that bank you can have your single phase 120 for lighting, dryers and electric oven on 208(has to be rated for it obviously) and your air conditioning and elevators on 240 3 phase. This would be a good set up for an apartment building, but could be used anywhere as long as you have the correct rating. You would have to have one of the transformers with a neutral coming of x2 though.
I could be wrong on some things as I'm digging a little deeper into banks that I havn't seen in person or worked on. I've only seen them in books.
