Question for fabricators
Fabricators know that steel and aluminum are basically sold by the pound, so the shape does not matter (unless it is a special shape or alloy).
Does anyone one know the current going price is (per/lb) for mild steel and 6061/6063 aluminum ?
dogdog
I had a similar questions, try to look for some scrap coupons for welding practice...
So in for the info
LXCam
A couple weeks back alu was $3.80~ lb at my place. I didn't pay attention to what steel was. Ouch.
Mark_17
The shape of the raw material will effect pricing- sheet/plate/bar/tube/pipe.
Quantity you buy and specs bought too will effect pricing as well. Pretty difficult to give a blanket answer.
dr_clyde
Holland, MI
Price can vary widely based on vendor, qty and alloy, as well as treatment. My prices are pretty much tailored to me, and won't be very useful to anyone else.
PugetDude
Superstition Mountains, AZ
Tubing and pipe cost more per # than hot-rolled shapes like angle and barstock. They're produced from cold-rolled steel that is rolled into a coil, then slit, rewound, shipped to a rolling mill, mounted on an uncoiler, rollformed, welded, weld skived, cut-to-length and then stacked and distributed for sale. Hot rolled shapes don't require all this secondary (value-added) processing.
dr_clyde
Holland, MI
For example, sheet and bar are very different prices, as well as hot vs cold rolled for a given alloy, and 2 tons is priced way different than 2 sheets.
ez-duzit
Marina del Rey
What kind of wizard are you if you need to start an entire thread to get a price, rather than simply Googling it? :)
dr_clyde
Holland, MI
You can't really google this kind of stuff if you want a fair price. Online metal sellers are by and large hugely overpriced. Quotes from local vendors are really the only accurate way.
matt_i
I disagree with the "pure pound" stuff. 1018 cold rolled round in 1/4" diameter (even in full bar lengths) sells at a price considerably higher than its "by weight" price unless you are buying tons of it.
I used to think cold rolled was reasonable around $1.00/lb in full bar lengths. Aluminum probably 2.5 to 3x, I don't buy enough to even know it offhand.
But, the prices of steel have shot up considerably, based on some shocking quotes I got for my day job, its not an ideal time to buy right now.
If you get a delivery from Alro its around $60 flat fee (may be more).
If they have to include a wooden skid to keep sheetmetal flat during transit, they charge for the pallet but I can't say exactly how much.
For little bits and pieces its going to be much higher, to the point that saving money is probably wasting gasoline.
BukitCase
Oregon
My supplier is Ram Steelco, in Salem/albany/portland - it's about 40 miles one way, they deliver (next day) for FREE if the order's over $100. I pick the whole bundle off their truck with my backhoe and they drive away...
Couple months ago tube, angle and flats were averaging $.70-$.75 a pound - I checked with 'em a couple weeks ago, it's $1-$1.10 a pound now (mild steel - I don't do aluminum much at all)...Steve
dogdog
$3.62 per pound today is or Contract Price. Not sure what the minimum is.
that looks like a good price, I just check online metalsupermarket... for 48x96x.125 6061-T6 cost $411 62lbs of alumnium @ aprox $6.63/lb... ouch
Not sure if going to store would be cheaper... Ebay scraps cost about the same too that is weird...
Muggzy
Orange Co., NY
I just paid $0.60/lb at R.S. Phillips Steel for drops of up to 36" of all kinds of shapes. Got a mix of some different thickness sheets and some hot and cold rolled bar as well. Gonna go back for some 1/4" wall x 4" square tube once I figure out a base for my grinder stand.
Sent from my Pixel XL using Tapatalk
4 FN 27
Minnesnowta
This morning:
Supplier #1: $3.33 per lb, no minimum landed on my dock.
Supplier #2: $3.38 per lb, 1000 lb minimum, landed on my dock.
Keep in mind we purchase about 600,000 pounds a year of Aluminum, 6 million pounds of CRS and 500,000 pounds of Stainless. This gives us a slight advantage in purchasing power. Nothing like John Deere might have.
T
That has not been my experience !
That I will agree on ! 6061 in any common extruded shape should be about the same price per pound. Clearly there will be a discount for large orders.
T
I am trying to get a very rough estimate of the cost of making an aluminum 2 axle, 7000 lb capacity trailer. In 6061 I would need at least 400-500 lbs 3x4, 0.170, extruded I-beam material.
kkroger
Price per pound varies also based on now many pounds you are buying... My vendors generally bottom out at 2000# of any one thing... and 100# vs 2000# changes the price per pound dramatically....
NUTTSGT
Northern Central Ohio
I used them once to buy some aluminum sheet. If was good priced but the other stuff was slightly higher than the local places.
https://www.metalsupermarkets.com/metals/
Blain
Starting a thread when all he has to do is call his local steel supply and ask.
gtae07
Fayetteville, GA
Which is a huge pain in the rear. You have to know exactly what you want in size and quantity (and without even having a list to look at and pick from), comparing a range of different options is extremely cumbersome ("so what about *** instead? Oh, that's too much... do you have anything like this? What's that in inches? Oh, not that either..."), and you tie up a person on the phone who rapidly gets irritated with you because you aren't calling up with a list of items and quantities in the format they want it, don't already have an account set up for pickup and delivery, and aren't ordering by the semi-truck load.
I really hate having to "call and get a quote" when all I'm doing is getting someone to look up on a computer screen and see what a price would be. I can do that for myself, and would infinitely prefer to do so at a time that is convenient to me and with the luxury of seeing all of the products and their prices, and being able to comparison shop at my leisure.
BD1
north side
You may consider buying the trailer. If your trailer needs specific details for your use than fabricating is best. By me, it's difficult to beat the price of a manufactured trailer.
I found prices vary from supplier to supplier as stated. Depending on suppliers on hand stock may influence price. Some sell as 20' lengths and others by the ton. Good shopping.
