DWinTX
Hi, I am about to start construction on a new detached garage. It will be 20' x 28' with 10' walls. I want to do a combination loft and open (cathedral style) ceiling. The open area will be 20' of the 28' length, and the remaining 8' will be the loft.
My goal here is to have enough height in the 20' span for a lift without worrying about ceiling height. The loft area will be for storage. I have 4 classic cars I am restoring and I have a LOT of parts.
I'm meeting with the contractor tomorrow to discuss how the garage will be built. I want to make sure that the open area is constructed with sufficient height.
I've read that there are two ways to frame without the normal ceiling joists, with a structural ridge beam on posts or with collar ties, which I guess is more a vaulted ceiling that a cathedral. I have one question on each:
If using a structural ridge, do the posts have to go straight down to the slab? I'll have a 16' garage door on one end and 6' double doors on the other. Can you run a post down to the door header and increase the strength of the header and it's supports sufficiently to support the roof?
If going the collar tie route, can anyone tell me how to calculate the ceiling height I would get? I've read that the collar ties can only go one third up the length of the rafters to still supply the torsional strength to prevent the ridge from sagging. My walls are 10', the span of the gable end is 20' and the roof pitch is 8/12. How high off the slab will the collar ties be if they one third up the length of the rafters?
Any help you can give me will be much appreciated. This is the first time I've contracted to build a building of any type, so I want to make sure I have the contractor do it the way that will work the best for my needs.
