I'd like to buy and install the Liftmaster 3800 jackshaft opener on my new doors. The instruction manual says not to use this opener if the drums are bigger than 6" and tapered. On one of my doors (the high lift one) the drums do not meet this restriction. The diameter is 7.5" for the first full turn of the drum then it's straight across, no taper with a diameter of just over 6.5" for the remainder of the turns. What's the reason for this restriction and will mine not work properly because of it?
Also, is the remote frequency compatible with craftsmen openers. I seem to recall Liftmaster makes the craftsmen.
