Question: Jointer Drive Pulley Size
tombell572
Sea Cliff, NY & Portland, OR
I just picked up a small, '50s era 4" Craftsman jointer, no motor or stand. The driven v-belt pulley on the cutter head is 1 3/4". Could anyone tell me the correct size or size range for the drive pulley at the motor shaft?
Thanks,
Tom B.
jakemac
New England
My guess would be 2". But if you post the model number, we may be able to find the manual over at Vintagemachinery to confirm. You'll also need to figure out what rpm the motor should be.
7th Kahuna
Los Angeles, CA
From the instructions for a Craftsman model 103.23340 4" Jointer:
It appears 5" may be the answer.
exmaxima1
Midwest
Thanks,
Tom B.
The calculations equate to a 2.25" drive pulley, but I would suggest getting newer larger pulleys on the order of 4" drive/3" driven using a 3450 rpm motor. The rationale being that you can transmit much more power using the larger diameter pulleys. Those small OD pulleys are noisy and hard on V-belts as well.
T
tombell572
Thanks, everyone-that gets me where I need to go. I have a 3450 Craftsman motor from a table saw "parts machine" that was purchased by a friend. I'll do the math from here.
Thanks!
Tom B.
