question of programable t-stat
sweetk30
finger lakes area upstate ,ny
so i have a modine hotdawg heater in my shop for min temp use in the winter set at 55 deg . i have a idea and was looking for feedback .
if the heater runs for around 10min each time it fires off is this to short of a run aka short cycle ?
if so how long should it run for a cycle ?
i have a std push the tab over to were you want the heat 20 buck t-stat 2 wire on it now .
do they make and if so what is a good model that will let you set the on AND off temp specs . not just a 3 degree difference or timed on/off .?
just want to keep my unit working as it should and not have a shortened life span .
The Cobbler
10 minutes should be fine. never timed my shop heater but I bet its right around there when its up to temp. my house furnace runs about 13 minutes .
I just have an electronic tstat that I bought from second hand shop . I don't like programmable stats, so I can't comment on them
