swampthang
- Joined
- Feb 13, 2012
- Messages
- 24
Planning on haveing a pole barn build soon and was going to insulate and finish thi inside myself. Im no carpenter so I learn by surfing the web and asking people. lots of heat and humidity in the summer and cold in the winter. I planned on putting a vapor barrier behind the tin that will be the ceiling of the garage then insulation. I was told that I also need a vapor under the actual tin that is the the outside roof as well, because the air in the attic will be warmer then the outside air. Is this correct or was I miss lead?
