green.bubbly
I just finished installing two Cooper VGF20W GFCI receptacles along with all the other receptacles. Before I buttoned everything up, I took out my meter and was checking for open circuits and shorts.
On the GFCI receptacles, does power have to be applied to read continuity between the line side and the load side?
Between the two hot screws, I have no continuity.
Between the two neutral screws, I have no continuity.
Between the contact inside the device and its screw, I have no continuity.
I am assuming that the receptacle is tripped and requires power to reset it? Pushing in the reset button does nothing. No click and no continuity.
lights, I would NOT own a 16g extension cord. (long story associated with it that could have hurt someone really bad)
