green.bubbly
This is actually a plumbing question so I did not know where to post it.
First off, I called my inspector for my open wall electrical inspection this morning. He hit me with depressing news. They prefer to do all the open walls at the same time. I was really trying to get the electrical inspection done so I could use the upcoming three day weekend to put up the interior wall sheathing.
So my plumbing and air conditioning needs to be done as well. Pretty straight forward on the plumbing. One cold water pex coming out the slab and one simple drain pipe. A/C is nothing terribly hard either. I just only have a few hours after work Wednesday and Thursday night so I can get the inspector out on Friday.
Problem one. I need to drill a 2.5 inch hole through three girts for the vent pipe. There has to be an easier way of drilling this size hole through metal??? I got one drilled but it was not fun. I used a hole saw bit like below which is made for wood of course. First issue is that as soon as the large hole bit hit the metal, it would bind and bend or break the center drill bit.
After three more bits, I ran out and ended up sticking a screw driver through the hole and into the hole saw bit. That actually worked a little better since the screw driver could flex without bending or breaking. But is there a better way?
Second question is on the drain vent. I want it to come out the back wall which is PBR steel siding. Anyone have any suggestions on flashing this? A regular roof flashing vent like below would more or less work if I could find one that is small enough to fit between the ridges of the PBR panel.
I actually just found this online at Lowes.com. If it is indeed 4" wide then that may work. Any other suggestions?
