Question on extending plumbing through drywall for faucets
Jay_OH
I'm in the process of finishing my garage and need some help with a plumbing question. Currently I have a hot and cold faucet which use boiler style valves attached to a concrete block fire wall. I'm framing with a 2x4 wall in front of the block which will be drywalled. What is the best way to extend this securely and make it look decent with finished drywall?
Anyone have a picture of what they did?
Thanks,
Jason
jeffmattero76
Thanks,
Jason
Are you talking about a faucet, or two separate boiler drain valves? Is there a sink below? If so, is it a laundry tub, or a regular type of sink?
Sent from my SM-G530T using Tapatalk
Radix2
the thumb!, MI
There are many "wall mounted" faucets. The thing you need to do is select one and then modify what you have to the appropriate fittings. They are not all alike and often need a specific adapter to go from npt pipe. The faucet will clamp to your final wall or sink.
Look at stainless steel commercial kitchen sinks and utility sinks. The are actually reasonable in price.
yeldogt
I guess you don't get freezing conditions ?
What do you want to attach to it -- Hose ? Faucet? Are you planning a sink?
If this is just a hose -- you can stub out two valves and make a central connection with a hose thread end. Make your own faucet ... the two valves picking the temp
J
Jay_OH
Sorry should of added more detail. This will be for hose only, no sink.
I think I may order one of the Woodford 122 faucets from the link I posted above. They are a little pricey but gives you a good secure way to mount and you can order with a variety of connection options for the plumbing side.
lionsgarage
Those Woodford valves will work great, I would eliminate the existing valves or put an access door for them.
I have the Woodford mud sil valves (frost free) on the outside of my garage for washing cars....very nice having hot water so close.
jeffmattero76
The other possibility that comes to mind doing is a washing machine ball valve shutoff. Here is a link to one
https://www.homedepot.com/p/TimeOut...-Automatic-Shut-off-Ball-Valve-2354/203535788
nh_yota
Seacoast New Hampshire
Get one of those Woodford combination valves and then cut/resolder the pipes with some wood blocking between studs to bring the valve out to the correct finished wall depth.
yeldogt
FYI -- The Woodford is really designed for freeze protection -- although you can order them with standard valves. I have the recessed enclosed box unit at one place -- w/standard valves.
I have had nothing but problems with various freeze proof valves ---- necessary evil.
Still think two threaded right angle valves -- to a central "T" w/ hose bib end is the answer. You will not have to change any of the existing plumbing and the stubs through the new wall can be sized to the wall thickness with ease.
tapered-pin
Alpharetta, GA
this may not be an issue for you, but, I don't see a drain line anywhere..
If you're only concerned with the rough-in - cut those copper lines, put 90* fittings in each and come out of the wall enough to clear the new framing and sheathing you're going to install.
I always use a 2X6 for blocking behind the 90s and put pipe clamps on them so they are beyond secure.
