pauls_workshop
I have a question for the forum. I'm doing a basement project and running the furnace outlet PVC pipe through a new wall with drywall. (Basically putting the drywall around the pipe already there). This is a high efficiency furnace. The pipe gets just a little warm to the touch when the furnace runs and that is all. What is the proper way to do this? Can I just plaster right up to the pipe and surround it with the drywall? Is a gap required and if so how much? Caulk? Foam? What to do?
I also have a hot water heater exhaust pipe that is in steel and gets much hotter. For that I'm going to use a proper metal thimble with 2" clearance all around through the wall. What is needed for the lower temp PVC above? thx! - Paul
