beemerphile
...There are no documented failures proven to be caused from using Honda fluids in a Honda.
Honda Z-1 ATF, after a lot of problems, was replaced with Honda DW-1 ATF which has its share of problems as well. The 6 speed trannies in my 2016 Pilot and 2018 Ridgeline will never see Honda ATF again. The 2016 Pilot cooked the DW-1 to coffee color in less than 30K miles. If you want to drain and fill the ****** at each oil change you can do ok. But there are much better fluids out there (such as Valvoline MaxLife Multi-Vehicle + a couple ounces of Lubeguard 61910 and AMsoil Signature or OE Synthetic ATF).
