Question on How to Make Sheetmetal Patch
olds70supreme
Hello,
I am trying to patch and reuse a core support and need the following piece (please view attachment). How would I go about putting the recessed channel in throughout the 90 degree bend. The bends are not quite sharp 90 degrees, there is a small radius to them. Is this what a shrinker/stretcher would be used for?
Thanks for the help.
  • core support patch.dwg Model (1).pdf
rsanter
visalia ca
you should ask that question at metalmeet.com
there are a couple of ways to do that.
1 you could make the part in 3 pieces. 2 straight sections and the radius section
2 you could make a long straight section and then cut the flanges out where the bend will be. make the bend and then mobify the removed pieces before welding them back in
3 you make this over a hammer form. I think you will have to use heat to make the shrink on the flanged sections.
a stretcher/shrinker will not work for this
bob
Rocket
Keith, South Australia
If I understand your drawing correctly,
the top hat section does a 90 deg bend with the narrow section on the out side.
The simplest way to make this is to bend the centre section (2 x 90 deg bends)
Then use a Shrinker to form the main bend by shrinking both sides.
then cut the centre of the sides out where the bend is & then turn up your sides.
All that is left to do is bend 2 small pieces & weld them in place.
Simple :thumbup:
I have formed a piece like this from one piece, but not with a Shrinker/Stretcher. So it can be done.
There has to be a lot of Shrink & then a lot of Stretch.
The Shrinker/Stretcher can't handle that amount (especially the Strecher, as it will tare the metal. Just the design of the jaws won't allow it)
I've you need some help, just pm me & I'll see what I can do.
CHEERS,
Rod.
