Question on installing Comfort Zone CZ220 Heater.
Leaky88
Illinois (Temporarily)
https://www.ruralking.com/comfort-zone-240v-5000w-garage-heater-cz220
Hi,
I have this heater I want to install in my attached garage where Main Power Panel is. It’s 5000W, draws 21A. Plan is to install Overhead, back wall, center. This will of course require a belly crawl through Insulation in the overhead from panel to back wall.
The heater has 2 Terminals for L1 and L2 and a point to secure the bare ground wire.
Question: Aside from the trivial cost savings by Manufacture, why is there not a 3rd Terminal for a dedicated Return? It seems this would not meet Code due to lack of grounding for Safety. Just asking.
Plan is to use more expensive 10/3 in lieu of 10/2 and err on side of safety.
If anyone has experience with this CZ220, I’d appreciate your feedback.
Thanks
Leaky
Hi,
Thanks
Leaky
A dedicated return? You mean a neutral? You are confused
240v utilization equipment does not have a neutral because it doesnt need it. A neutral is for 120v voltage.
I do not understand your last sentence. The heater has a grounding terminal.
Also, you dont need 10/3 which is 2 hots neutral and ground. Get 10/2.
Bert_
NW Iowa
It has no need for a neutral. The ground is already just for safety. It would function fine without the ground unless it develops a short to the metal case.
10/3 is a waste unless you like parking extra wire in a wall. Why not leaving an unopened roll in the attic or something. It would do the same amount of good.
Bert_
NW Iowa
The more I read the original post the more I think the op does not understand how split phase AC works. Never to late to learn.
Power will flow from L1 to L2 without any need for a neutral. The neutral is only used if you want 120v
zippi
Southern Indiana
I just installed this heater in my garage a couple months ago. I used 10/2 (orange) wire plus a 30 amp 220 breaker. Two wires are hot plus a ground. Works great.
zippi
Southern Indiana
Hi,
Thanks
Leaky
Leaky,
PM sent
nadogail
Coronado, CA
Because I tapped my heater off the 50 AMP circuit feeding the receptacle I plug my arc welder into. I protect the cable, and control the heater, with a 30 AMP fused disconnect.
When I want heat I push the handle UP when I am comfortable I pull it down.
Before the Flame Cannons are loaded, my tap conductors are less than ten feet long.
