My pole barn is going up this week, 24x36x12. I plan on doing blown in and probably liner panels for ceiling and I'm thinking either the wide rolls of fiberglass insulation for pole barns or just regular batts covered woth either osb or liner panel. Depending on cost of liner panel.
My question is on the walls. They're using house wrap under the siding for the walls.
1) Can I roll out the wide rolled insulation and put it flat against the wall perlins and then put up my bookshelf 2x4s to fasten sheets to? Or will the gaps defeat the purpose?
2) if I use batts or regular rolled, I was planning on putting it in horizontal in-between the wall perlins then taping seams.
My understanding is if they use the house wrap, then I wouldn't use faced insulation correct?
