Sorry for in advance for no pictures, I'll have to shoot some later.
Buddies garage in question, 3 car (double door, single door) from previous owner. Was never insulated, so we decided for building cars in the winter (Volkswagens), we had to insulate it. A couple questions for all of you:
First Question:
A couple weeks ago, we insulated all the walls with R-13 (10 foot tall, 15" spread framing) that has a paper backing. Now the question is, we're not sure if we are going to sheetrock the walls or put plywood over them, but should we install a plastic vapor barrier over the insulation?
Second Question:
The ceiling is open trusses, and I know we can't insulate the actual roof because with the ridge vent, the heat would be lost. So should we just plywood the ceiling and throw R-13 (or higher) insulation on top of the plywood in between the rafters/trusses (we will be building an attic door).
Third question:
Should we pull the garage door track feet and openers from the ceiling and plywood in between them and the trusses, or should we just cut around them?
First Question:
Second Question:
Third question:
