Question on interior vapor barrier for walls and ceiling
SALIV8
chicago and s/w michigan
If I decide to go with interior metal siding for my walls/ceiling and insulate behind this metal siding (blow in)do I still need a plastic vapor barrier between the insulation and the metal?
I don't think so but what do I know..lol
p_mori7
Montreal, QC., Canada
I would say 'Yes'.
The vapor barrier prevents the flow of air through the wall (even with insulation).
Unless your metal interior sheathing is 100% (or very close to 100%) impermeable once installed, you should install a poly vapor barrier.
kbs2244
If by "blow in" you mean something dry you are also going to need a moisture barrier between the insulation and the outside wall.
If you are talking about foam it will be it's own moisture barrier.
