Question on metal fabrication
bw77
Upstate NY
I would like to know how the corner of this toolbox tray was made. The end piece was bent at a 90* angle, and it is attached to the side piece. My question is how was it attached? JB weld? Something else.
The divider inside the tray is similar, but I can see marks every 3" or so, that look like finish nail heads would look on wood. What are those?
I didn't take metal shop in hs.
A_Pmech
IL
It is spot welded.
The "finish nail heads" you see are the tong marks left by the spot welder.
Tantara
+1
Technically resistance spot welds. Two electrical contacts pressed on each side of the base metal, than enough current is passed through the contacts to fuse the base metal. Goes quick a second or so per spot.
Brad
kwb
PNW
Robots can do spot welds or run a MIG torch amongst other things.
