Question on substituting household breaker
gygeneral
Ontario, Canada
I would like to replace a 240v breaker on my panel with two individual 120v breakers. I've attached a pic of the panel where the single 240v breaker was and also pictures of what I took out. I need a few individual circuits and this one was not being used. Question can I do this? I can't think why not but I tought I better ask to make sure there is something I'm not seeing.
Thanks for your input
mcj115
Hershey PA
First go simple...check you model of box to see if there are slimline breakers available where you can fit two 120v circuits in one space.
G
gygeneral
Ontario, Canada
Ok so I need thinner breakers to start with to fit in that space. Makes sense didn't realize that. Make of breakers is Square D not sure about the box off hand. But I will check tomorrow.
I got questioning myself when I seen the little tabs where it gets the power from going to the upper bar and the other from the lower bar.
Many thanks
Chuckster in NJ
Hunterdon County NJ
Yes you can do this!
Just buy TWO single pole Square D QO breakers and install them and abandon the two wires that were on the double pole breaker...... Hand a tag on the abandoned wires saying where they went to.
dfiler2
NW Minnesota
Square D has Homline and QO, those appear to be "QO", the 120 volt will generally be half the width of the 240 volt.
G
gygeneral
Ontario, Canada
Thanks everyone, it appears based on the size I can install two regular size breakers in place of the 240v one i took out. This 240v wasn't being used so I don't have to worry about any existing wiring.
Hardware Stores will be allowed to open with some restrictions on May 9th around here, so you know where I will be that day.
Many thanks:beer:
mike93lx
Richmond, VA
I would be installing a pair of tandem 120v breakers if the panel is full already. You'll go from adding 2 circuits to adding space for 4 and it will save you from doing this all over when you need to add something else down the road
G
gygeneral
Ontario, Canada
Good idea, if I have to buy breakers anyhow , this would make sense
mike93lx
Richmond, VA
Just make sure the spaces are listed for them. Should indicate on the label of the panel. Some panels only allow for certain spaces to take tandems
