question on used vac gauge dial/needle position
steveo3002
cambridge england
i got this older snap on vac gauge that id like to move on , i notice the needle is a hair outside the "blue" zone
would you consider this an issue ? id like to sell it but wouldnt like to mislead anyone /sell cr@p
steveo3002
cambridge england
it works both ways ive used it
i dont have another known accurate tester to compare it with...all im asking is the needle resting where it ought to ?
No, unless you made some tool purchases that really ****, that should be at 0 when not connected. Not sure it matters, haven’t paid attention to the scales on mine in 35 years.
engineer2
Chicago burbs
On some gauges you can simply pull the needle off and put it back on in the correct position.
On other gauges you need a needle puller to avoid damaging the internal mechanism.
On some more expensive gauges there may be a zero adjustment.
If you reset the needle, you still need to check it against a known accurate gauge
fsae0607
San Fernando Valley, CA
Hook it up to a known good Mityvac and compare the vacuum readings. If it's off, you'll know the offset.
Same with pressure. Borrow someone's good fuel pressure gauge, find a test vehicle, hook them up with a tee fitting and compare readings.
ttpete
Dearborn, MI
You'll never have absolute accuracy with that gauge, and for its intended use, ballpark accuracy is all that's needed. The fact that the zero mark is so wide confirms this.
2ndGearRubber
Pittsburgh
Carburated test vehicle.
Do not hook that up to an EFI vehicle. 100kpa is about 1 atmosphere, or 15psi. That gauge isnt meant to see 60psi.
Compare the gauge to a mity vac or another gauge. Some do have manual zero adjustment inside, depends.
