Kevin54
MEMBER EMERITUS
The truck is wired for both electric and electric over hydraulic trailer brakes.The trailer itself will have brakes.
I have 16 2"x27' Erickson straps that should be lots I would think I also will have a tarp to cover it to keep it dry.
I wasn't sure about the different State laws,do you have to pull in the weigh scales if they are lit up?
CC
You are good to go and shouldn't have any problems. Just make sure before you take off that the tags are up to date and the lights and turn signals work. Also make sure you have enough ratchet straps to hold things down. Ten miles down the road and you'll feel like you been doing it forever. The only other thingt to worry about is the stopping distance. It takes a little longer to stop than without a trailer so you have to compensate for that. Drive safe and drive defensively because of other drivers that don't pay attention.
