transittech
- Joined
- Feb 27, 2012
- Messages
- 299
So,
I am rebuilding an old Walker (Ajax branded) 2 ton floor jack and I have some questions about it. (I already have a rebuild kit, but have further questions)
1. Is this the correct order for the check valves in the first picture? I put all the pieces in individual bags when I took it apart, but I must have mixed something up, because one piece definitely didn't fit where I had it. I don't know where the small square spacer fits. D'oh!
2. The main ram has some 'heavy' scoring from before, its bad enough I can feel it with my finger after honing. Can't get a good picture, I've tried 2 dozen pics. I have buffed it a lot with 500 grit sandpaper, and its still there, BUT it is much better than before. It held pressure fine and didn't leak down at all before taking it apart, but the fluid was sludge, literally. Should I worry about it? This jack has many MILES on it, literally, and I just want it to be safe.
3. I would like to remove the main pivot to lube and re-assemble, but it seems frozen. Should I try harder? Does it just press out?
4. This jack is missing a few zerk fittings; the front wheels, and the main pivot. Are they press in or are they something else? I could put it in a press, but don't want to break it if its not supposed to come apart this way.
Thanks for your help!
