Questions about ArmorSeal 1000HS
P-51
Ok, my other option (other than VCT) is to use 1000HS as I think it's the best/only thing available in Canada. We seem to only have water based epoxy at the big home stores.
So here's my questions:
My garage is about 450-500sq.ft. How many "kits" will I need to do one coat? I know there's a part A, and part B. Are they 1 gallon each, or is it 1 gallon of A, and a pint of B? The application rate is 200-350ft/gal, is that per gallon of just the A, so one "kit" does 200-350, or is it per gallon of mixture, so one "kit" would would 400-700?
Basically, I'm trying to figure out how many "kits" I'd need for two coats.
And then, if I want to do a clear coat, is it going to take 1 or 2 kits?
mhoffm911
I think most "kits" cover approximately 250 sq ft once mixed. In this case, you would need 2 kits of colored expoxy. My understanding is that the clear coat goes on thinner, so you may be able to get by with 1 kit (I would do 2 if it were me).
