cactiki
Hi garage people. Well, it looks like I can finally fix the garage roof, so now i have a few questions. I am planning to go with pbr panels because I don't want to ever do this job again. I have a 33' x 26' roof which previously had rolled roofing on it. I say previously because it is all gone now! Over the last few years (ok 18....) it has all been blown off by our Mojave desert winds. Fortunately we only get about 5 inches of rain per year, but still a lot of the plywood sheathing is in bad shape because it has been exposed to the elements. I have been trying to research this online but still am not sure the best way to go, so here are my options:
1: remove and replace all sheathing, then attach the metal to the plywood, with a vapor barrier between them.
2: leave the sheathing in place, and run stringers of 1 x 4 (or 2 x 4??) horizontally, 24" on center. This way I could put fan fold insulation in the space between.
I am wondering if there is any reason to remove the sheathing and replace it. It is not going to fall in on me, but it is weak enough I wouldn't want to walk on it or attach my metal to it. If I use 1 x 4s, will it be strong enough to walk on? What about 4" wide strips of 3/4" plywood, wouldn't that be stronger? And can you walk on a roof of these metal panels? They seem like they would bend. Does anyone know of a good website about installing metal roofing? Any thoughts, suggestions, or recommendations? Thanks for reading and hopefully responding to my post.
