Questions about nut type;
Olafur
Iceland
Ok I come across these to often and I am always in trouble dealing with them. Think pinion nuts etc
dont mind the small locking screws;
iu
1) What do you call this type of nut.
2) Are they made to standard (many?) metric/sae?
3) Anyone seen socket sets for them including several sizes?
PCustoms
VT
Name escapes me at the moment, but we have some fairly large (150mm is small, IIRC we have a 450mm) in metric thread pitch. We typally use a brash punch or chisel and hammer to get them moving
O
Olafur
Iceland
Sounds familiar. I am currently rebuilding the front differential from 300 hp Fendt farm tractor. Pinion nut is like this. Getting the old one off is the easy part. Assembling and testing the contact pattern several times and finally applying 500 Nm for the final torque is different story.
Jim Diesel
Brisbane, Australia
See them for wheel bearings on heavy equipment all the time. Generaly use specail hub nut sockets.
Also pop up on diff output bearings and seals, usualy use a c- spanner for them.
gungatim
west mich
looks like a locking ring on the AR-15 platform telescoping buttstock assembly. there are special wrenches that engage the notches to loosen/tighten them. have seen them on drillpresses as well...
KnurledNut
n/a
Ive always called them a collar nut.
Generally a hook spanner works. They also make them with a square drive for torque applications.
(Pics courtesy of google)
IMDIN70852.JPG_
hautpot
California
I hate these types of nuts. They dominate the CNC tooling world for collets.
We usually don't use hook spanners, but specific spanners that fits better than hooks with more teeth engaging:
