SMOKEEATERFF
I have some questions for you guys. I have been reading for weeks and have seen mixed answers. I will eventually be building a 30x48x12 pole barn with concrete slab. I plan on enclosing it myself to save on costs, probably bookshelf girts.
As far as the slab what thickness, do I need rebar, what about fiber, 4500 psi okay? I plan on working inside of it and storing my old tractor weight is about 6000 lbs. No plans on a lift or anything like that. Some have said rebar isn't necessary others say it is. If it is necessary how much would that add to the costs as far as materials? Should I use fiber? I plan on having the foundation prepped right and a vapor barrier laid with joints cut. Also 4" or 6"?
Electrical-I have a 200 AMP box on my pole going to my house. My pole barn would be maybe 200 ft away. Can I run off of this box or would I need to have new service at the barn? I am by no means an electrician.
