ScaldedDog
We are closing this week on a home with a roughly 43x35x10 pole barn (Morton building), that I'll use to store and work on vehicles. It's well insulated (though I don't know how), with metal walls and a perforated metal ceiling. I've had a really, really nice garage (that you guys helped me design and build - see my threads since 2008), but I'm completely new to pole barns. So, I have questions:
1) How do I attach things to the walls? I had OSB-under-drywall before, and so could attach small things anywhere, and Gladiator Geartrack, for example, to through the OSB to the studs. I trust the "poles" are the analog of the studs in a pole barn, but how do I locate them? Is wiring generally buried deep in a pole barn's walls, or do I have to be concerned that it could be right under the metal?
2) If I want to run additional wiring, conduit or copper tubing in the walls, can I easily take down a section of the metal and get it back up, good as new?
I'm sure I'll have more questions once I'm in, and if these are so newb that there's a "Pole Barns for Dummies" someplace that'll answer them, please do me a solid and point me in that direction. In the meantime, here's a pic of the outside, and one from the inside with the current owner's stuff:
And here's what I'm coming from, so you know I'm not a total newb, just a pole barn newb:
Thanks!
Mark
Thanks!
Mark
