BlackLead
I'm looking into putting heat in the garage. 48x22 with 9' ceilings, 3 bays plus work area. Insulated walls, sheetrock, insulated doors. Checking BTU sizing on various calculators on the internets, I get readings all across the board, from 27k up to 115k?! Holy ****. I'm guessing it's more art than science. At any rate, I'm thinking around 40k will do what I need. I'm looking for about a 50 degree temp differential, since I live in a fairly warm climate (south Mississippi). My original thinking was to use two smaller heaters to divide the space about equally, but a Mr Heater 25k unit seems to be about $300, while the 40k version can be had for less than $100 more?
I keep thinking that two heaters would work better at balancing the heat, but that's a considerable price difference. For those with a single heater in the garage, of the radiant gas type, how does it do for keeping the whole space warmed? Good enough, or do you wish it was better distributed? And if anyone knowledgeable can tell me if 40k is about right, or not, I'd appreciate that input too.
