scutty83
I just installed a subpanel for my basement (attached structure) and have a few questions.
1. The feeder wire (2-2-2-4 AL with thermal insulation) is a 60' run. Am I correct that it falls in the 60C and needs to be breakered at 75 amps?
2. When hooking up service the ground and neutral are bonded at main panel and isolated @ subpanel, right?
3. Whoever ran the electrical to the main level of the house wired each room with its own breaker but combined lighting and outlets on that one breaker. Is it acceptable to continue that in the basement or do I need to wire outlets and lighting on seperate circuits?
4. I have counted 25 lights at approximately 60watts a piece (1500w total) and 20 outlets that will run on the (75A) panel. I would like to rewire the hot water heater and furnace to the sub if possible.
