Questions on air compressor plumbing
shouse
Yea, I know, it's been beaten to death quite a bit already. I'm following the pdf diagram from TPTools (https://www.tptools.com/tech-metal-piping.dlp) as well as what I've found from searching. I really just have one question. I'm going with black iron piping and a lot of folks recommend sloping the pipe back to the tank. My question is HOW w/ black iron piping. I'm only aware of 90* and 45* fittings and I do not have access to a pipe bender (not for black iron pipe anyways). I plan on doing a zig-zag down my wall and trying to slope it sure would add a lot of complexity?
Is sloping necessary? I noticed the pdf diagram doesn't indicate it at all? Any ingenious ideas on how to get it done? Copper isn't an option unfortunately.
Thanks
thebeekeeper1
Illinois
Don't they just mean in the first few feet? You can use 45* fittings for that. After that you use drops with a ball valve at the bottom to purge them, with a "T" above for your quick-connects. :)
Rossco
Great White North
Well I sloped my pipe towards the drip leg. The riser from the compressor is the highest point in the system.
Even with 3/4 main line, having the Riser and mainline perfectly square, the pipe will flex slightly to allow a slight slope to the next coupler, T or elbow.
shouse
Perfect, that makes sense, thanks. I'm sloping upwards away from the tank for the first few feet. Afterwards, I'll follow the natural bending principle, should make things a lot easier. Thanks again.
jallyn
Fort Wayne, Indiana
Right, just a very slight amount is enough, so just use a bubble level and make sure it is slightly off center when securing the pipe.
Boilerhouse
Muskoka
The pipe will have a natural tendency to droop, however, it should still be supported to remove excessive strain from fittings. The downward slope of the line should be in the direction of air flow.
