Questions on Bendpak XPR-10A
Low50s
NE Iowa
I found a Bendpak XPR-10A on CL semi local to me for a OK price lift is about 4 years old according to date of MFG pics show the lift set up in Asymmetric but in the picture of the "floorplan" from bendpak paper and it snows symmetric is this a lift that can be set up either? I would prefer a symmetric lift because I lift alot of trucks and SUV's does anyone know if this can be set up as either ? I did some google and came up with nothing was thinking someone here may own one?
killahog
Morrow County Ohio
No, The support that runs across the top would not fit correctly there are steel plates that fit inside the posts and they are cut to match the the angles the posts are offset at. I switched my posts from left to right in order to have my power unit on the driver side to kept it away from my workbench. I had to modify where the cable sheves were located to do this. The picture of from above the lift to show the braces I was talking about.
Partsguy57
No I have one.... I lift trucks suvs all the time. Just load them symmetric...
Sent from my SM-G920R4 using Tapatalk
