robertearl
I just got a used Miller 211 from the local welding supply store for $1000. I was trying to order some tips, diffuser, and nozzles. The manual that came with it seems to imply that I have an MDX-100 gun. When I start looking for parts I see many accessory kits for M-10,M-20,M-40,M100,M150 etc. but very few mention MDX-100. My diffuser has D-M100 stamped on it. Do I need to find stuff for an MDX-100 or is an M-10 or M-100 the same thing.
I found some T-M023 tips as all it came with was .030 tips. I have also seen mention that to use .023 wire I also need to change out the liner. Is that true? I always thought that you could use .023 wire in a .030 liner.
Do Hobart tips work with the 211 or do I have to look for Miller tips?
Thanks
Reb
Thanks
Reb
