robs400
Looking for some input on required sheetrock for code. Being that I knocked a hole in my basement wall and put in a garage door, I technically need to treat the area as a garage space and would like to sheet rock the space to code.
I'll attach a pic...because people like pics and it seems to help when starting a new thread.
The space is currently further along than shown, but this is the only pic I have of the walls and ceiling I am talking about. The wall in the background that has a door on it I plan on sheetrocking with 2 layers of 5/8" thk. board. I believe that is the code requirement.
Does the first layer need a coat of mud and tape? Or can it simply be hung and then put the second layer right on top?
The ceiling? I have been told that it only needs one layer of 5/8" thk. I do not understand why 2 would be required on a wall but not on a ceiling tho? (there is living space above it).
I did the ceiling in my garage that has no living space above it and attached the sheetrock right to the bottom of the trusses. I was told for the area in the pic tho that I should run strapping first and then screw the sheetrock to that. What exactly does the strapping do? If its spaced the same distance as the floor joists currently are but running the other direction, I'm not seeing what its purpose is?
Thanks for the input!
