Finally completed enough new house projects that I could start on some important stuff: my garage! I began putting up cleats to hang my cabinets and realized that there are a lot of issues to deal with, posibbilities to consider and questions to answer. I could never keep up with multiple threads so I'm going to just keep a single thread and see what I can learn from all the gurus around here.
Shop Specifics (SS):
1 Located in Texas (Dallas Area)
2 20x20x9
3 South facing garage door (pressed steel). The tracks are bowed out and the door is not insulated.
4 Liftmaster 1/2 hp door
5 GFCI outlet in North Wall
6 Outlet in ceiling
7 Outlet in west wall (for Verizon box)
8 Single incandescent bulb in center of garage
9 Outlets are on one circuit
10 Lights/garage door are on one circuit
11 Slab w/ Lowes brand "epoxy" (from previous owner). Chipping off
12 Raised 2' section at north wall
13 Only north wall is attached to the house. Only north wall is insulated
14 Attic above garage is not insulated (to my knowledge)
15 Soffit vents on east and west walls
16 Single roof vent (unpowered to my knowledge)
17 North wall not plumb (joint at ceiling began to separate when screwing in cleats)
18 Garage will be used for woodworking (furniture, small boxes, etc.)
19 No-name compressor (30 years old, 2'x3' footprint)
20 Tablesaw (Ridgid TS150)
21 14" Bandsaw (Grizzly GS550X)
Wants (W):
1 More comfortable work environment (cooler).
2 More outlets. The west wall outlet is mounted 3" down from the ceiling and the east wall has no outlet.
3 Dedicated circuit(s) for garage outlets and lights.
4 Floor coating of some sort.
5 More lighting. Flourescent in the field with some halogen cabinet undermounts.
Questions (Q):
1 The garage is not air conditioned. If I insulate it won't I just be trapping the heat inside?
2 If I do insulate what would my most bang for buck get me? The attic is not easily accessible but the drywall would have to come down to insulate the walls so attic might be the way to go.
3 Is it wise to try and run my own new outlets? I'm not an electician so I would have to read up on it. What is the cost to have it done? I'm looking to add circuits to my panel for dedicated garage service and I'm betting that's beyond my abilities even if I read up.
4 Are permits needed to add outlets and lights to my garage? I think the answer is yes, but figured I'd ask. New outlets and fuses seem like new construction but I expect lights to stay on the existing circuit so maybe I don't need one.
5 ...
I know there's more but I'm bushed and drawing a blank. Thanks for any advice, comments, answers, etc. Love the site.
2 20x20x9
6 Outlet in ceiling
Wants (W):
Questions (Q):
5 ...
