david5253
Hi Everyone,
Long time lurker, first time poster. Really enjoy all the info available here. I have a subpanel in a detached garage fed from a 200 amp service in the house. See the attached pictures. It was inspected and approved with 3 wires and a ground attached to the garage footers. The neutral bar is bonded to the panel. Is this correct?
I am using MHF 2-2-2-4 wire to feed another subpanel in a detached building about 50 feet away. I will be using a 90 amp breaker to supply that. I have installed 2 ground rods at the new location. Question: Do I use a bonding screw on the new panel or separate the neutrals and the grounds in the load center? Also how would you recommend that I connect the 1 1/2" conduit to the load center in the garage. Do they make a box extender for a Homeline load center so I could go straight in from the side or how about a flexible conduit into top?
Thanks in advance for your help. I'm in Colorado and we're under the 2014 NEC
